  Visitors: 5480
CAD tip CAD tip # 13852:
How to bulk-update all model parameters?
A - answer If you have a parametric design in Autodesk Inventor with a number of separate (independent) parameters, you can update these parameters in bulk using an iLogic rule.
The example in the following iLogic code rounds all numeric parameters starting with "d" (and not calculated from other parameters) to two decimal places. Metric parameters are assumed.
For Each param As Inventor.Parameter In ThisDoc.Document.ComponentDefinition.Parameters
  If param.Name.StartsWith("d",False) Then 'starts with d
    If param.DrivenBy.Count = 0 Then ' not computed
      If param.Units<>"Text" And param.Units<>"Boolean" Then 'numeric only
        Try
          param.Value = Math.Round(param.Value, 2) 'process, e.g. round to 2 decimals
        Catch
        End Try
      End If
    End If
  End If
Next
Inventor
3.9.2023    853×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13836:How to reset view numbering in Inventor?
Tip 13744:Simple password protection of Inventor documents (iLogic).
Tip 13197:How to transfer a model or sketch parameter to iProperties?
Tip 12508:How to assign an expression (not value) to a user parameter with iLogic?
Tip 12462:Mass- (table-) rename parameters in Inventor.
