Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 11374:
Question
If you want to suppress displaying the welcome screen when launching Fabrication, use the following procedure:
Open (in Windows) the menu item Start > All Programs > Fabrication CAMduct > Edit Configuration
on the CAMduct tab, check the option Hide Welcome screen
After you restart CAMduct, the welcome screen is no longer displayed.
Before/After:
FabricationCAMduct
100% *CAD,CAM
4.4.2017    12990×
Share the tip:
applies to: Fabrication · CAMduct ·
Tip 13266:Where can I find the MAKEPAT command in Fabrication CAMduct?
Tip 9568:What are the .RIF, .MAJ and .EST files?
Back    All CAD Tips
Categ:
