  Visitors: 6323
CAD tip CAD tip # 7077:
How to display 4 grips in the corners of MText?
A - answer If you are used to manipulating MText objects with the four grips in the corners of the text frame, you can still use them instead of the simplified grips of MTexts in AutoCAD 2010 (and higher).
To return to the pre-2010 behaviour of mtext grips, switch off dynamic columns. Before you create the text, set the MTEXTCOLUMN variable to 0 (instead of the default 2). If you want to change an existing paragraph text object, change its property (Ctrl+1) "Columns" to "No columns".
ACAD2010LT2010ADT2010
26.11.2009    18075×
Prices - CAD eShop:
Tip 13426:Use of alternative units for arithmetic in dimensions (without square brackets).
Tip 11289:Adding, multiplying and rounding numbers inside DWG drawing texts - NumInText.
Tip 11223:Copy multiple DWG drawing texts to the Windows Clipboard.
Tip 11171:Total number of layouts as a field (Page 3 of 7).
Tip 10952:All DWG texts in UPPERCASE.
