CAD tip # 12537:
applies to: Revit 2020 · Revit 2016 · |
Tip 12926: | How to import point coordinates from Excel to AutoCAD? |
Tip 12766: | Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge |
Tip 12136: | Security settings for Inventor data files and add-on applications. |
Tip 11953: | How to save PDF/A-1a archive from CAD software AutoCAD, Inventor, Revit? |
Tip 11502: | How to detect DWG files created as an export from Autodesk Revit? |
US projection in Inventor drawings.
Drawing perpendiculars from any curve in AutoCAD. « | » Error when inserting standard part - Modeling: Failed to insert a part into assembly!
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
