Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 14190:
Question
If you have layers, layouts, views or other tables in your DWG file named with non-Latin characters, e.g.:
お客様サポート
бронирования
, you can bulk rename them to standard names using the RRename utility.
Load RRename into your AutoCAD (see the tip 9265) and first set the global operations in this utility:
(setq RRenameGlobal T)
Run the RRENAME command, select the rename type (e.g. layers) and select the following as the regular expression search string:
[^\x1F-\x3E\x40-\x7F]
(i.e. characters outside the standard ASCII character range, plus the "?" character)
Replace these characters with e.g. "X" or "_".
ACADADTPlantACADMCivilMap
29.7.2024    2039×
Share the tip:
Tip 14223:Arithmetic operations for renaming blocks, levels, layouts...
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 9265:RENAME on steroids - complex renaming of AutoCAD objects (blocks, layers...)
Back    All CAD Tips
Categ:
