Over 1.095.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 12908:
Question
Since the version AutoCAD Plant 3D 2022 it is possible to transfer project settings with the tool Project Compare, which you can find in the menu Project manager on the Home tab:
After launching this tool, you can open another project from your local disk, from Vault or from the cloud service Autodesk BIM 360. The tool the compares settings in both projects and displays any differences detected:
You can then browse the individual settings and copy them to your current project.
An example of such transfer:
Plant2022
30.3.2021    13273×
Share the tip:
applies to: AutoCAD Plant 3D 2022 ·
Tip 14593:Revit is slow on a new workstation on structural and steel connections projects.
Tip 14392:How to get rid of the dot displayed by P&ID symbols in Plant 3D?
Tip 14349:12 free material texture libraries for PBR rendering.
Tip 14310:Easy graphical display of the project or assembly file structure (hidden function).
Tip 14232:How to find out the fillet radius of a 3D solid?
Back    All CAD Tips
Categ:
