  Visitors: 4145
CAD tip CAD tip # 13536:
iLogic: How to find if a document is a sheet metal part and if it contains holes?
A - answer An example of iLogic code that can be used to verify that the current document is a sheet metal part (sheetmetal .IPT) and whether or not it contains holes (both modeled and flat pattern holes).
You can use one of these three suggested methods to determine the type, resp. subtype of the "Sheet Metal" document:
If iProperties.Value("Project", "Document SubType Name") = "Sheet Metal" Then
 MsgBox("This is sheet metal 1")
End If
If ThisApplication.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
 MsgBox("This is sheet metal 2")
End If
Dim oPDoc As PartDocument = ThisDoc.Document
If TypeOf oPDoc.ComponentDefinition Is SheetMetalComponentDefinition Then
 MsgBox("This is sheet metal 3")
End If
Then use this iLogic code snippet to verify the presence of holes in the current sheet metal part:
i = 0
'folded model holes?
For Each oFeature In ThisDoc.Document.ComponentDefinition.Features
 If oFeature.Type = ObjectTypeEnum.kHoleFeatureObject Then
  i = i + 1
 End If
Next
'flat pattern holes?
For Each oFeature In ThisDoc.Document.ComponentDefinition.FlatPattern.Features
  i= i + 1
 End If
Next
If i > 0 Then
 MsgBox("Contains holes")
Else
 MsgBox("Does NOT contain holes")
End If
Inventor
13.11.2022    3947×
Prices - CAD eShop:
applies to: Inventor ·
Tip 9692:Unfoldable spiral-helix sheet metal in Inventor.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
