  Visitors: 9913
CAD tip CAD tip # 9692:
Unfoldable spiral-helix sheet metal in Inventor.
A - answer With a spiral curve and an iLogic macro you can create a spiral-helix sheet metal (worm, screw) in Inventor and then unfold this 3D part. The procedure is illustrated in this video:
(co-author of this tip: Wili)
An alternative way for irregular helixes Tip 9300 (in Czech).
Inventor
5.2.2014    9419×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13183:Lin2Cyl - bulk conversion of lines to 3D cylinders.
Tip 12479:PkLength - export line lenghts to Excel.
Tip 12471:What for is the Bank option of the SWEEP command?
Tip 10708:Modeling compression injection screw for molding machine.
Tip 10138:Dimensioning a curve length or distance between two points on a curve.
