  Visitors: 4720
CAD tip CAD tip # 6686:
MSI Error 1325. [username] is not a valid short file name
A - answer AutoCAD or other Autodesk product fails on installation or on the first run with the Error 1325.
This is a MSI installer error appearing on user accounts with names containing a dot (".") or with names longer than 11 characters. Users' login names probably have a period in their usernames - i.e.: "first.last".
What to do:
Install your CAD product in the Administrator account and then copy the Registry entries (HKEY_CURRENT_USER\Software\Autodesk) and the folders c:\Users\[username]\AppData\Local\Autodesk and c:\Users\[username]\AppData\Roaming\Autodesk.
ACADInventorRevitmax
20.5.2009    39752×
applies to: AutoCAD · Inventor · Revit · 3ds Max ·
Tip 13539:Revit 2023.1 shows "Twinmotion is not installed"
Tip 13263:Error when renaming assembly files in Design Assistant 2022.
Tip 12605:Script error (utag) when trying to log-in with your Autodesk ID.
Tip 11863:You cannot install this product on the current operating system.
Tip 11854:iLogic error in Inventor 2019: invocation of constructor threw an exception
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
