Over 1.097.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 1337:
Question
File FormatImportExport
DXF 2D/3Dyesyes
ACIS (SAT) 3Dyesyes
3DS (max) 3Dyesyes
ePlot (DWF) 2D/3D- (attach only)yes
Windows Metafile (WMF) 2Dyesyes
PostScript (EPS) 2D-yes
Stereolitography (STL) 3D-yes
HPGL 2Dyes (Express Tools)yes (Plot)
VRML 3D-- (VRMLout)
DirectX 3D-- (DirectX export)
ACADMDT
18.5.2001    14720×
Share the tip:
applies to: AutoCAD · MDT ·
Tip 14620:Converting object data (OD) to XData (XD) in AutoCAD Map 3D.
Tip 14526:How to export geometry from AutoCAD DWGs to JSON files and import it back?
Tip 14496:Convert scanned point clouds or photos to BIM objects - Scan-to-BIM.
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14433:AR view of 3D model from AutoCAD, Inventor, Revit, Fusion
Back    All CAD Tips
Categ:
