Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 1412:
Question
Use the AREA command with the Object option to calculate the area of a solid. Surface area of the selected 3D solid is displayed as "Area".
You have to use a true solid 3D body, not a mesh - e.g. a revolved object has to be a product of the REVOLVE command, not REVSURF.
ACADADTMap
20.6.2001    23859×
Share the tip:
Tip 14443:Connector, notch, groove, cutout or other curve- breaks - easily with dynamic blocks.
Tip 14347:PDFIMPORT - No objects were imported.
Tip 14250:How to select all lines of the same length or boundary polylines of the same area?
Tip 14177:How to scale an object to reach the target area?
Tip 14106:Printing of the underlay map with a light background.
Back    All CAD Tips
Categ:
