  Visitors: 6189
CAD tip CAD tip # 2154:
How to change the size (scale) of OLE object in a drawing?
A - answer Select the inserted OLE object and run the _OLESCALE command. In its dialog you can change the object size, aspect ratio, text font and size plus print quality of the selected object.
ACAD2000
100% Win  CAD
3.5.2002    23056×
Prices - CAD eShop:
applies to: AutoCAD 2000 ·
Tip 7678:Converting raster image to a matrix of pixels inside the DWG.
Tip 6304:How to insert a live-updated XLS table in an AutoCAD drawing?
Tip 5535:An effective way to bind raster images inside DWG files.
Tip 5010:Attaching a voice message to a DWG drawing.
Tip 4718:Arc text in AutoCAD LT.
