Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 2714:
Question
The type of drawing view is controlled by the AMPROJTYPE variable. In the Mechanical Options dialog (AMOPTIONS command), tab Standards, in the tree on the right choose the "book" with the name of the standard and right-click. Choose the Properties option and Projection Type setting.
MDT6
4.12.2002    6883×
Share the tip:
applies to: MDT6 ·
Tip 14503:Compare the performance of creating arrays/patterns in Inventor.
Tip 14232:How to find out the fillet radius of a 3D solid?
Tip 13944:Intersection of a 3D spline with a plane in Fusion 360.
Tip 13296:How to correctly load a KML/KMZ file into Civil or Map 3D?
Tip 13173:How to convert projection of a 3D model to a 2D DXF drawing?
Back    All CAD Tips
Categ:
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
