Over 1.097.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 3102:
Question
Use the following trick to print tiled AutoCAD drawing e.g. A3-size sheet on a A4-size printer or fax.
First 'ePlot' your drawing - plot or publish your drawing to a .DWF format. Start Autodesk Express Viewer or Autodesk DWF Viewer (free CAD viewers, see DL Download) and in the Print dialog select your output format (print to scale). Choose 'Tile drawing'. Use Display tiles to see the dividing lines between print tiles (there is an automatic overlap and position marks). Then simply print these tiles as separate pages to your small format printer (or fax).
ACADACLTADTMapRevitInventor
16.6.2003    37158×
Share the tip:
Tip 13773:What is the maximum paper size when plotting from AutoCAD?
Tip 10461:Unattended DWG plotting and PDF publishing without AutoCAD.
Tip 9998:Automatically rotate drawings plotted from Revit or other software.
Tip 9972:Create free 3D PDF output files from any CAD software.
Tip 8425:Batch print for multiple drawings, multiple printers and copies.
Back    All CAD Tips
Categ:
