  Visitors: 9419
CAD tip CAD tip # 3232:
My texts are printed as outlines only (hollow).
A - answer TrueType fonts are not filled (are plotted as outlines) on printing/plotting, rendering and EPS export, when the TEXTFILL variable is set to 0.
Try to set the TEXTFILL variable to 1, make sure you are using a non-rendered, non-hide-lines, plan view.
ACADLTADTMapMDT
4.8.2003    30471×   FAQ
Prices - CAD eShop:
Tip 13791:Part number from the Frame Generator is not transferred to the Part Number iProperty.
Tip 12326:How to customize your Fusion 360 background color? (any color theme)
Tip 11983:How to use iLogic code to fill username into iProperties?
Tip 11982:Creating table with parcel numbers and areas - AreaTab.
Tip 11794:Undocumented code in field expression - MText contents without control characters.
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
