  Visitors: 9321
CAD tip CAD tip # 3317:
How to make an Inventor workplane bigger?
A - answer Right-click on the work-plane (in model or tree-view) and uncheck the Auto-Resize option. Now you can drag the grips to resize your workplane.
In an assembly switch selection prioriry (Shift-RtClick) to Feature priority.
Inventor
29.9.2003    15292×
Prices - CAD eShop:
applies to: Inventor ·
Tip 14006:Universal MsgBox in AutoLISP.
Tip 13996:Automatic hide for Revit palettes - save screen space (undocumented).
Tip 13305:Where can I find the icon to run Civil 3D 2023 as AutoCAD?
Tip 13228:DWG or DXF file exported to/from Fusion 360 has incorrect size (scale, 10x larger/smaller).
Tip 12933:Purging small objects from a DWG drawing - PurgeSmall.
