Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 3958:
Question
With the free utility by ARKANCE - LinOut - you can automatically generate (extract) a linetype definition file (.LIN) back from your DWG drawing (incl. the shape+text information from complex linetypes).
Load the VLX utility in your AutoCAD session (with the main DWG drawing) with APPLOAD and start (type in) the LinOut command. It creates a .LIN file in the same folder (and same name) as your DWG drawing.
LinOut is available for download on DL Download.
Version 1.3 fixes handling of multi-text lines.
The older LINOUT1 command supports just plain linetypes (not the complex ones).
For hatch patterns use the PatOut utility
ACADADTMapMDTACLT
2.8.2004    54142×
Share the tip:
Tip 14477:PurgeAll - automation of DWG file cleaning
Tip 14417:Quick calculator on an AutoCAD keyboard shortcut.
Tip 13716:HYPERLIST - list of all used URLs.
Tip 13485:Multi-line keynotes in Revit.
Tip 13450:How to create a complex line type with text always upside down?
Back    All CAD Tips
Categ:
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
