  Visitors: 9755
CAD tip CAD tip # 4078:
Rubik's cube in Inventor.
A - answer On the Download page you can download a complete 3D assembly of the popular puzzle Rubik's cube created in Autodesk Inventor 9. The Rubik's cube model contains all neccessary constraints so you can manipulate it like the real puzzle.
Don't forget to Activate the Contact Solver (Tools menu). Then you can rotate the individual 'levels' of the cube either using the "Drive_me" constraints (use the Drive constraint funtion on mouse rt-click, leave the small step in the control dialog), or freely - so that you switch off the above mentioned constrain (mouse rt-click) and then move the levels with your mouse (as with the real-life cube you should exactly finish the 90° step rotation, otherwise your cube will fall apart).
You can hardly break the world record in solving the 'Cube' puzzle by hand - currently 16.5 sec., but e.g. using Inventor VBA macros opens interesting options for machine-solving of this puzzle, which can take 43,252,003,274,489,856,000 configurations in total...
model author: Sonja Ahrens
Inventor9
18.10.2004    26397×
Prices - CAD eShop:
applies to: Inventor 9 ·
Tip 13824:How to export OBJ including materials, textures from Inventor?
Tip 13699:How to synchronize camera orientation in different Inventor views?
Tip 13592:Searching in the Inventor assembly model.
Tip 13280:How to publish models in USD/USDz format from Inventor?
Tip 13273:Missing options when importing STEP files into Inventor.
