  Visitors: 5008
CAD tip CAD tip # 4372:
Disabling animated zoom/pan in AutoCAD 2006 (and higher).
A - answer AutoCAD 2006 (and higher) performs the view updates triggered by zooming, or view panning/rotating in a slow, animated manner (so that user doesn't loose the view context).
If you want to change parameters (speed) of this 'soft' zoom or to switch it off completely, use the _VTOPTIONS command, or directly the VTENABLE variable.
ACAD2006LT2006ADT2006Map2006
25.4.2005    35938×
Prices - CAD eShop:
Tip 13514:Why does the Power dimensioning command zoom my drawing?
Tip 13437:Zoom on predefined annotation scales.
Tip 12914:Geo2GPS - web map from any coordinate of an AutoCAD DWG.
Tip 11835:Shared Views to your DWG drawings - easy collaboration with collegues and clients.
Tip 11004:AutoCAD forgets window-selected objects when zoomed off screen.
