Over 1.099.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 4467:
Question
If you want to enable or disable plotting or publishing "on the background" (without interrupting your work), you can use the command option (checkbox) or the BACKGROUNDPLOT variable (value 0 switches off both background plotting and publishing).
Commands started from a script run always on foreground.
Background plotting run from a temporary folder BGPlot_number in your temporary files directory.
ACAD2005ACAD2006ACLTADTMap
8.6.2005    25381×
Share the tip:
Tip 14481:How to bulk publish a folder of DWG/DXF files to PDF?
Tip 13977:How to publish a PDF to the same folder as a DWG drawing in AutoCAD?
Tip 11841:How to set output folder for AutoCAD plot to file?
Tip 11171:Total number of layouts as a field (e.g. "Page 3 of 7").
Tip 10182:How to create a PDF file from DWG without AutoCAD?
Back    All CAD Tips
Categ:
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
