Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 4647:
Question
If you want to stop users editing dynamic blocks (or if you want to use the old REFEDIT on block-dblclicks), you can switch off the new dynamic block editor through the BLOCKEDITLOCK system variable.
Setting this variable to 1 locks off the BEDIT command and double-click on a dynamic block starts just the reference editor or attribute editor.
You can watch changes of this variable with the Xanadu SysVarLock utility (see Tip 4241).
You can also right-click on a block to choose between the BEDIT and REFEDIT editors
ACAD2008ACAD2007ACAD2006ACLT
21.9.2005    14317×
Share the tip:
Tip 14537:Automation of AutoCAD drawing texts using fields.
Tip 14526:How to export geometry from AutoCAD DWGs to JSON files and import it back?
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 14443:Connector, notch, groove, cutout or other curve- breaks - easily with dynamic blocks.
Tip 14402:What is the difference between the BLOCKREPLACE, BREPLACE, REPLACEBLOCK, RIBLOCK and BLKREDEF commands?
Back    All CAD Tips
Categ:
