Over 1.099.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 4651:
Question
In Architectural Desktop, this new function of AutoCAD 2006 is off by default. Just set the DYNPROMPT variable to 1 and press the DYN button in the status line.
Or rt-click on the DYN button, go to Settings and check the "Show command prompting and command input near the crosshairs" option.
ADT2006
23.9.2005    11720×
Share the tip:
Tip 14665:Display complex linetypes on 3D curves in plain AutoCAD.
Tip 14615:How to create negative dimensions in AutoCAD?
Tip 14604:QRcode - dynamically generated QR codes in AutoCAD.
Tip 14526:How to export geometry from AutoCAD DWGs to JSON files and import it back?
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Back    All CAD Tips
Categ:
VRMLout More info
