Over 1.094.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 5371:
Question
Windows Explorer running under the 64-bit version of Windows doesn't offer the Pack-n-Go function of Inventor 11.
The Pack-and-Go function is available only in the 32-bit version of Windows Explorer. You can switch between the 64-bit and 32-bit version of Explorer with the icon Autodesk32bitExplorerLauncher.bat on the Windows XP x64 desktop. If this icon is missing, you can switch Explorer using the command:
c:\windows\syswow64\explorer.exe /separate
Inventor11
100% WinXP64CAD
21.1.2007    10770×
Share the tip:
applies to: Inventor 11 ·
Tip 14471:What is the Golaem app included in the Autodesk Media and Entertainment Collection?
Tip 9197:Export of 3D CAD models to Google Earth.
Tip 9032:How to install AutoCAD 2013 or Inventor 2013 in Windows 8?
Tip 8921:How to terminate Autodesk Sync (AdSync.exe)?
Tip 7847:FIND does not stay zoomed on the found text.
Back    All CAD Tips
Categ:
