Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 5540:
Question
The visualization application Autodesk VIZ 2008 can process and convert (besides its native formats .MAX and .DRF) also the following file formats:
Import: .CHR (Character Studio), .3DS/.PRJ (3D Studio), .AI (Illustrator), .DEM/.DDF (LandXML), .DWG/.DXF (AutoCAD), .FBX/.DAE (Autodesk/Collada), .IGS (IGES), .IPT/.IAM (Autodesk Inventor), .LS/.VW/.LP (LightScape), .SHP (3D Studio), .STL (Stereolithography), .WRL/.WRZ (VRML), .XML (VIZ material).
Export: .3DS (3D Studio), .AI (Illustrator), .ASE (ASCII scene), .ATR (LS material), .BLK (LS block), .DF (LS parameter), .DWF (Autodesk), .DWG/.DXF (AutoCAD), .FBX/.DAE (Autodesk), .IGS (IGES), .LAY (LS layer), .LP (LS preparation), .STL (Stereolithography), .VW (LS view), .W3D (Shockwave 3D), .WRL (VRML97).
Besides these formats VIZ supports also many raster and animation formats for material textures and rendering output.
VIZ2008
1.5.2007    13719×
Share the tip:
applies to: VIZ2008 ·
Tip 8225:Integration of foreign CAD data into Autodesk Navisworks.
Tip 6153:How to generate Piranesi EPix files from AutoCAD and 3ds Max?
Tip 5625:Creeping plants for 3D objects.
Tip 5516:Missing 3DSOUT command in AutoCAD 2009/2008/2007.
Tip 4678:Publish 3D DWF files from CAD applications.
Back    All CAD Tips
Categ:
