  Visitors: 13061
CAD tip CAD tip # 5661:
DWG open or Zoom All causes an INTERNAL ERROR: !dbutil.cpp@705
A - answer or !dbutil.cpp@807
Your current DWG drawing is corrupted. It may be caused by a technical hardware/communication error, by a faulty add-on application, or (most probably) your DWG file was created in a non-Autodesk software and has an improper internal structure (format).
Forged DWG files saved from Microstation, ArchiCAD, SolidWorks, ZwCAD, TurboCAD, ProgeCAD, SolidEdge 2D etc. can cause similar problems when processed later in AutoCAD. Typical problems occur in layer operations, zoom, layout functions, 3D and during printing/plotting/publishing.
ACADLT
17.7.2007    13981×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 13868:XrefStamp - create a dynamic list of xrefs in your DWG drawing.
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 13583:Evaluate math expressions in AutoCAD DWG texts.
