Over 1.099.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
Try the new precise Engineering calculator and the updated Barcode generator.
New AutoCAD 2026 commands and variables.
CAD tip # 6043:
Question
Loading certain ARX applications incompatible with the MDE mode (multiple-documents environment) can automatically disable the MDI mode (see the SDI variable). The SDI variable is temporarily set to 2 by this.
In the single-document mode (SDI) the CLOSE command is not available.
ACADADTACADMCivil
26.3.2008
8128×
