CAD tip # 6119:
Tip 13878: | SelectSimilar - extended selections for AutoCAD, incl. LT and Web versions |
Tip 13868: | XrefStamp - create a dynamic list of xrefs in your DWG drawing. |
Tip 13784: | Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT? |
Tip 13737: | Formatting leading zeros in AutoCAD fields (and automatic field update). |
How to set margin (trim) for reference parts in an Inventor drawing? « | » To simplify A2009 migration, I want to see both the classic menu and the ribbon. How can I do it?
Featuring: Increase your productivity with our set of BIM add-on functions for Autodesk Revit CADstudio Revit Tools ![]() |
