  Visitors: 8974
CAD tip CAD tip # 6160:
How to update/refresh a modified style in Inventor?
A - answer Styles and standards you edit with the style eeditor (Format > Styles and standards editor, command SE), are automatically updated (refreshed) also in all relevant drawing views.
There is an exception to this rule - the styles which have the setting "Default" in their definition (parameters). Such styles are not associative and can be used only for the initial setting of object styles - they are not connected to the individual instances of drawing objects. If you want to make changes to the appearance of such objects, you have to update them individually. This applies e.g. to hatch pattern definitions (details, sections). You can edit hatches by righ-clicking, choosing Edit and reselecting the same style.
Inventor
4.6.2008    10236×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13920:Saving your Inventor model in the presentation color scheme (iLogic).
Tip 13911:How to print all sheets at once from Inventor?
Tip 13884:How to send e-mails with an iLogic macro?
Tip 13852:How to bulk-update all model parameters?
Tip 13836:How to reset view numbering in Inventor?
