Over 1.099.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
Try the new precise Engineering calculator and the updated Barcode generator.
New AutoCAD 2026 commands and variables.
CAD tip # 6173:
Question
When you export an AutoCAD 2007 drawing to the .CAL raster format and set resolution to 400dpi or higher, AutoCAD may fail with a fatal error.
Apply the CAL Format hotfix for your AutoCAD 2007.
ACAD2007ACLT2007ADT2007Map2007Civil2007
13.6.2008
9551×
applies to: AutoCAD 2007 · AutoCAD LT 2007 · AutoCAD Architecture 2007 · AutoCAD Map 3D 2007 · Civil 3D 2007 ·
