Over 1.092.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 6277:
Question
If you want to switch off the 3D rotate view function (3D-orbit) assigned by default to the combination Shift+wheel (rollerwheel), you can change or disable this assignment in the CUI command.
You can find this function in the CUI dialog under Mouse buttons > Shift+click > Button 3: Transparent orbit (assigned command 3DORBITTRANSPARENT).
If you want to use this combination (Shift + dragging with mouse-wheel pressed) for orthogonal panning in 2D, you need to press first the wheel, then the Shift key.
ACAD2009ACAD2008
21.8.2008
54969×
applies to: AutoCAD 2009 · AutoCAD 2008 ·
