  Visitors: 8163
CAD tip CAD tip # 6495:
AutoCAD does not show hyperlinks of my drawing objects.
A - answer If AutoCAD does not display the link cursor (earth globe) and the tooltip with the link attached to an entity (with the HYPERLINK command), you have probably switched it off with the HYPERLINKOPTIONS command.
ACADLT
23.1.2009    6897×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 13716:HYPERLIST - list of all used URLs.
Tip 13522:LookupXLS - populating DWG texts from Excel spreadsheets.
Tip 11757:How to change blocks properties ex-post: annotative, allow exploding, scale uniformly
Tip 10301:How to export PDF with hyperlinks from AutoCAD?
Tip 6881:List all hyperlinks in your DWG drawing.
VRMLout More info
