Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 6630:
Question
With the change of the rendering engine in AutoCAD 2007 (and higher) the special "landscape" objects (trees, shrubs, cars, people..) are no longer available (the former LSNEW, LSLIB commands).
There are some workarounds for adding entourage objects to your 3D scenes for rendering:
  • Use full 3D models of entourage objects - see e.g. the Block library
  • Add the entourage pictures only as 2D images to the rendered picture (postprocessing in Photoshop)
  • Use an alternative rendering tool - e.g. 3ds Max, Piranesi...
  • Use the simplified, render-ready RPC objects from ArchVision - see their offering to AutoCAD users.
  • Make simplified (planar, crossed) models with materials using texture maps and opacity maps (orient them to your camera) - see below
How to add opacity-based planar models to your scene for rendering:
  • Run the MATERIALS editor.
  • In the Materials tool palette, click "Create new material" and name it.
  • In the Template drop-down list, select Advanced.
  • Select the Diffuse Map check box.
  • Select Texture Map from the drop-down list.
  • Click the "Select Image" button and select the image you want to use for your entourage object (tree, people...).
  • In the "Material Scaling" section, set the "Scale units" to "Fit to Gizmo" and set U and V tile to 1.00 (in version 2007: Adjust Bitmap > Bitmap Scale > Fit to object).
  • In the Opacity section, click "Select Image", and then browse to a opacity image file (black will not show, white will show the diffuse map image).
  • And finally - create a 3D face in your DWG scene and apply the new material to it. Now you can render the drawing.
ACAD2010ACAD2009ACAD2008ACAD2007ADT
20.4.2009    27665×
Share the tip:
Tip 14509:AutoCAD linetypes - the A/R/U orientation options in complex text-linetypes.
Tip 14349:12 free material texture libraries for PBR rendering.
Tip 14027:3D heart from the heart.
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
Tip 13557:How to create an image with transparent background in Fusion 360?
Back    All CAD Tips
Categ:
LogOff 2006 More info
