  Visitors: 9383
CAD tip CAD tip # 6662:
DGN import/export error - "You do not have permission to save to this location".
A - answer You do not have permission to save to this location. Contact your administrator to save to this location.
This error (during DGNIMPORT/DGNEXPORT) is caused by improper location of the DGN mapping and setup file DGNSETUPS.INI - Windws 7 and Windows Vista (UAC) protects files in root disk folders and in the folders Program Files and Windows. Or you have the file in another read-only directory. Direct this file rather to a read-write folder with user files - see OPTIONS > Files (the last item), or the variable DGNMAPPINGPATH.
The default location is in the subfolder Support in the folder defined by the ROAMABLEROOTPREFIX variable.
ACAD2010ACAD2009LT2009ADT2009Civil2009
100% Win7,Vista,WinXP  CAD
5.5.2009    14258×
Tip 9739:Size of a saved DWG file grows unexpectedly.
Tip 9698:Data formats supported in Autodesk InfraWorks 360.
Tip 9553:Complete thorough PURGE on a single click.
Tip 9363:How to hide the frame of a wipeout, embedded DWF or DGN?
Tip 8460:Unusual AutoCAD linetypes - from Microstation RSC files.
