Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 871:
Question
You can insert your raster image even in AutoCAD LT 2000 (besides embedding through the INSERTOBJ command). Just use a trick with a predefined template drawing.
E.g.:
Open a new drawing using a template (Use a Template), choose the template by pressing the Browse... button, click on the globe icon (Search in WWW) and in the Look in box enter:
http://www.cadstudio.cz/dl/raster.dwt, press Open (you can also download the template file to your PC and use it locally).
Now you can use the _IMAGE command to set the real path to your raster image (for multiple images use a template with more images inserted). This functionality (plus much more) is also a part of the CADstudio LT Extension add-on product for AutoCAD LT.
For the 2000/i and 2002 versions see also the Tip 3254.
AutoCAD LT 2009, 2010, 2011 and higher can already attach (insert) raster images directly with the IMAGEATTACH command.
ACLT2011ACLT2010ACLT2008ACLT2006ACLT2004ACLT2002ACLT2000
8.1.2001    157471×
Share the tip:
Tip 13131:How to crop an image or PDF underlay in Revit?
Tip 12361:Seamlessly connected images by irregular clipping in AutoCAD (or LT).
Tip 7919:Loading Photoshop PSD images into AutoCAD.
Tip 5174:Inserting images into AutoCAD LT drawings.
Tip 4158:Transparent raster images in AutoCAD.
Back    All CAD Tips
Categ:
