CAD tip # 12446:
applies to: AutoCAD · |
Tip 12813: | How to set both upper and lower dimension tolerances as negative (or positive). |
Tip 12790: | Centered dynamic label (e.g. area label). |
Tip 12697: | Opposite angle for angular dimensions in Inventor drawings (iLogic). |
Tip 12335: | The FLAY utility suddenly places texts and dimensions in wrong layers. |
Tip 12264: | How to show dimension tolerance in a different color? |
How to explode block attributes keeping their text?
Pan view (change view target) in multiple viewports of a layout. « | » Non-modal (permanent) iProperties window in Inventor - SelectionInfo.
Featuring: DwgTextTranslator translates a series of drawings from one language to another using MS Access. Download a fully functional trial version. |
CAD Studio is not responsible for possible problems that may occur as a result of using any of these tips.
