CAD tip # 13227:
applies to: AutoCAD · AutoCAD Architecture · AutoCAD Plant 3D · AutoCAD Mechanical · Civil 3D · AutoCAD Map 3D · Inventor · Revit · 3ds Max · VRED · PowerMill · |
Tip 12977: | Easily find CAD/BIM document references (including missing ones) - Reference Explorer |
Tip 12667: | How to free up space in the local cache of Desktop Connector? |
Tip 12184: | Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD). |
Tip 11959: | Supported file types (applications) with reference detection in Autodesk Desktop Connector. |
DWG or DXF file exported to/from Fusion 360 has incorrect size (scale, 10x larger/smaller). « | » Attractor - snap multiple objects to existing points/vertices.
Featuring: Increase your productivity with our set of BIM add-on functions for Autodesk Revit CADstudio Revit Tools ![]() |
