Over 1.097.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 11835:
Question
With the new function in AutoCAD 2019 - Shared Views (SHAREDVIEWS, the ribbon Collaborate > Share > Shared views) you can easily share your CAD design with your remote collegues and customers, without posting (and risking) your original DWG file.
The above mentioned command opens the SHARED VIEWS palette a there you can click on "New Shared View" (or enter the SHAREVIEW command). In the dialog "Share View" you can then choose the share name and other sharing parameters.
The function will generate a private cloud image of your drawing and creates a shortened unique web-link (URL) on "slovak" domain - e.g. https://autode.sk/2pDvqjr. This link is valid for 30 days (can be prolonged - see Extend) and you can hand it to your collaborators to display and review your drawing inside any web browser - the collaborator doesn't need any CAD nor any other software. Their reactions and comments will be displayed directly in your SHARED VIEWS palette as Comments.
The web CAD viewer (localized in many languages) offers functions to enable/disable layers, switch views, measuring, printing and displaying properties of the individual selected drawing objects (if they were published). The comments are related to the respective zoom level (drawing detail).
A similar function is available also in Inventor.
ACAD2019ACLT2019Inventor
25.3.2018    11801×
Share the tip:
applies to: AutoCAD 2019 · AutoCAD LT 2019 · Inventor ·
Tip 14604:QRcode - dynamically generated QR codes in AutoCAD.
Tip 14481:How to bulk publish a folder of DWG/DXF files to PDF?
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 13316:Concerned about security of your Fusion designs? Where are hosted your USD Viewer files?
Tip 11926:What is the Autodesk Screencast Group?
Back    All CAD Tips
Categ:
LogOff 2006 More info
