Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 7728:
Question
Solid fills in AutoCAD drawings publihed to PDF files may contain visual artifacts (random lines) when viewed on a screen.
This behavior can appear with any AutoCAD version, any PDF driver (both free/shareware and AutoCAD internal driver), any PDF viewer.
We recommend to use the AutoCAD internal PDF driver (available in current AutoCAD versions). You may increase its resolution/precision setting. You can also consider using the DWF publishing format.
In any case this is only a display problem - solid fills are plotted and printed without streaks.
ACAD
14.1.2011    36091×
Share the tip:
applies to: AutoCAD ·
Tip 11953:How to save PDF/A-1a archive from CAD software AutoCAD, Inventor, Revit?
Tip 9153:Arrowheads or other parts of dimensions are not printed.
Tip 7549:DEPENDS - displaying file dependencies in a DWG drawing.
Tip 4513:Negative (inverse) viewing of CAD and PDF files.
Tip 3232:My texts are printed as outlines only (hollow).
Back    All CAD Tips
Categ:
LogOff 2006 More info
