  Visitors: 9477
CAD tip CAD tip # 8785:
What is the maximum resolution of Inventor video animations?
A - answer The highest resolution of video animations from Autodesk Inventor Studio is 4096 x 4096 pixels. This is the rendering limitation, your current video codec may apply other, additional limitations to this render limit. E.g. for direct rendering to WMV video files there is a maximum resolution of 1200 x 1024 pixels.
To create presentation quality hi-res videos we recommend to use the frame-by-frame mode (image sequences), or to use the network rendering of the video in Autodesk 3ds Max, as scene processing in such high resolutions can be very time consuming (in terms of CPU computing time).
Inventor
28.8.2012    12334×
Prices - CAD eShop:
applies to: Inventor ·
Tip 13513:How to quickly record a video from a CAD application or other Windows program? (replacing Screencast)
Tip 11818:How to change resolution of images in the Clash Detective report in Navisworks?
Tip 11464:How to make a fast Inventor Studio animation without rendering?
Tip 10296:Using cloud render in Fusion 360.
Tip 8330:Rendering stereoscopic images in 3ds Max (anaglyphs).
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
