Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 13659:
Question
If the setting of the DIMLAYER variable is other than a period (".") or "use current", the newly created dimensions will be placed into the layer specified by the value of this variable, not into your current layer in the DWG drawing.
To return to the original behavior, type DIMLAYER and type a period to return the behavior of the dimensions to the default settings.
ACAD2023ACLT2023ADTCivilACADMPlant
9.3.2023    17907×
Share the tip:
Tip 14268:How to set the background mask color to BYLAYER?
Tip 14045:In my AutoCAD script file (.SCR) I cannot enter a name containing a space.
Tip 13358:Restore the last deleted entity in the DWG.
Tip 12705:How to disable osnaps for xref objects?
Tip 12335:The FLAY utility suddenly places texts and dimensions in wrong layers.
Back    All CAD Tips
Categ:
