RSS discussions
Discussion Discussion forum
Topic Closedblock not eraseable
 Post Reply Post Reply Page  12>
Author
reyad102 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: block not eraseable
    Posted: 04.Sep.2010 at 17:57
how could I make a block not eraseable in my drawing?
reyad
Back to Top
Cad64 View Drop Down
Senior Member
Senior Member
Using: Autocad 2011, 3DS Max 2011, Photoshop CS5
Status: Offline
Direct Link To This Post Posted: 05.Sep.2010 at 17:38
Put it on a locked layer.
Online Portfolio: http://www.rdeweese.com/
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 07.Sep.2010 at 15:19
but you can unlock that layer and erase it....I would like it not eraseable???
reyad
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 07.Sep.2010 at 15:51
You want to make it so that it can NEVER be erased??? Sorry, I don't think that's possible, and, I don't even know why you would want to do that?
Back to Top
Kajito View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 10.Sep.2010 at 22:11
well try to insert it as reference. From my experience I know that many people still do not know how to work with references and they are trying to delete such objects with no luck :))
Back to Top
deepu View Drop Down
Newbie
Newbie
Using: autocad2007
Status: Offline
Direct Link To This Post Posted: 13.Sep.2010 at 09:59
tell me why u want to protect like this. if u want to protect your file u can use password.
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 13.Sep.2010 at 18:21
to enshure that no one change my dwg.
reyad
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 14.Sep.2010 at 02:45
There is software out there that will supposedly lock a drawing, making it uneditable. You might want to check out that option. The program I'm referring to is called CadLock. Google it for more information.
Back to Top
haithamsitto View Drop Down
Newbie
Newbie
Using: Acad2010
Status: Offline
Direct Link To This Post Posted: 14.Sep.2010 at 04:54
I have never run into a situation where a file provided to me was not changeable.  Even as a reference, the block has to be available to reference. If you have a concern about your drawing not being changed, don’t share it in a cad format, send a pdf file.  Even those can now be vectorized and changed as needed if your know how to do it.  We do this all day long because the clients provide us with paper line drawings.
Back to Top
jmattingly View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 14.Sep.2010 at 23:48
When you create the block, there is a setting, so it will not explode.  Just click on the box in your block editor.  Hope this helps.
J
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,129 seconds.
