RSS discussions
Discussion Discussion forum
Topic ClosedNeed help
 Post Reply Post Reply
Author
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Topic: Need help
    Posted: 25.Apr.2008 at 10:00
You can increase the relative scale of your dim texts (see Dim Styles), or you can dimension in the paperspace (layout) to keep your dimensions independent on model scale, or you can use a text style with fixed height.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
blackdog View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 24.Apr.2008 at 18:18
Hello,
         I am trying to print a drawing (backyard deck plans) that I made with acad2008 to my HP deskjet. When the drawing is reduced the dimensions text is also reduced (so small can't read). How do I print the drawing but end up with a legible font size when printed?
Back to Top
dictum View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 27.Feb.2008 at 14:36
Back to Top
Sombra View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 26.Feb.2008 at 23:24
Why not just keep the drawing in millimeters and then when you need to dimension, change the dimstyle scale factor? Or, if you're just doing a "dist" (distance) command in autocad, you simply move the decimal place to the right 3 places. Millimeters, and metric for that matter, is so simple and easy to work with, there's no real need to change the scale of the drawing.
Edited by Sombra - 26.Feb.2008 at 23:25
Back to Top
LatCh View Drop Down
Groupie
Groupie
Using: Revit
Status: Offline
Direct Link To This Post Posted: 12.Jan.2008 at 17:03
Scale the drawing globally - use the SCALE command, select all objects and enter the scale factor.
Back to Top
anilnavis View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 12.Jan.2008 at 08:59
thanks .. each time i have to select the one by one ? to change the measurement ?
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 09.Jan.2008 at 15:52
You can either just set a multiplication factor in your dimension style, or scale down your drawing 1000x (SCALE command, 0.001).
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 09.Jan.2008 at 15:46
Hello i am new autocad i  am using the 2006 version
 i have a question. I got a cd design did by someone
its units in millimeter . but  want to change the unit to meter is it possible ..
When i take measurement the length should be in meter is its posssible.
Thanks
Anil
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,145 seconds.
