RSS discussions
Discussion Discussion forum
Topic ClosedPlotting Problem
 Post Reply Post Reply
Author
Natnorth View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: Plotting Problem
    Posted: 19.Mar.2008 at 11:50
My Autocad 2006 has just begun to give intermittent plotting errors. Everything goes fine until the end, when the plot log says 'Job Canceled', although the number of errors and warnings is given as zero.
This does not seem to depend on what printer is being used.
Help Please!
Nat
Back to Top
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 19.Mar.2008 at 15:51
Help Please!
Maybe you don't installed correct it should have tip *.pc3 in your lists of printers.
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 19.Mar.2008 at 16:05
Thank you for the suggestion, though I do not think this can be the problem. The program has been installed for several years, and I have not changed it or the printers, and the problem only affects some files - it seems to be file-dependent.
Nat
Back to Top
sebgonz View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 20.Mar.2008 at 13:24
Have you checked if your plotter is out of memory? Read tip 5519. That sounds similar to your issue.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,329 seconds.
