RSS discussions
Discussion Discussion forum
Topic Closedproblem with layers
 Post Reply Post Reply Page  12>
Author
ahmedsobhe View Drop Down
Newbie
Newbie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Topic: problem with layers
    Posted: 24.Sep.2011 at 22:48
hey guys ..
I am trying to to export ( layer status ) through layer status manager to a *.las file , so I can use the same layer properties in another CAD file , but it always can't export line types :( is it a fatal mistake in AutoCAD or what ?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 24.Sep.2011 at 23:08
You could always export your linetypes to a custom.lin file using a lisp routine called TO-LIN.LSP or LLTYPES.LSP.  A link to the first, and the actual lisp file for the second can be found here...http://forums.cadalyst.com/showthread.php?t=5601.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Posted: 29.Sep.2011 at 13:59
Could you please explain your idea in steps ?
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 29.Sep.2011 at 15:46
My idea addresses only the linetype issue.
<<AutoCAD 2015>>
Back to Top
v_85259 View Drop Down
Newbie
Newbie
Using: revit 2011
Status: Offline
Direct Link To This Post Posted: 30.Sep.2011 at 07:40
Dear friend
what u r problem.u transfer layer or line type.
pls tell me
Thanks
Venkateshan.s
venkateshan
Back to Top
Newbie
Newbie
Using: revit 2011
Status: Offline
Direct Link To This Post Posted: 30.Sep.2011 at 07:41
pls tell me
u r  transfer layer or line type
thanks
s.venkateshan
venkateshan
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 30.Sep.2011 at 12:08
There is no "transfer".  All the routine does is write a line definition to a new .LIN file which can then be used on another computer.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: revit 2011
Status: Offline
Direct Link To This Post Posted: 03.Oct.2011 at 07:13
dear friend
new.LIN file load any computer automatically come in line type that computer
venkateshan
Back to Top
Newbie
Newbie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Posted: 03.Oct.2011 at 20:13
What i am asking about is ( transferring layers properties ) to a *.lsa file , with that file I can reuse this layer properties on another CAD file
I noticed that AutoCAD always tells me that line type could not be transferred to the new file however the layers (name,color,line wight .. etc ) are always successfully transferred to the new file, ( line type ) failed in this process.. could any one help me please ?
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 04.Oct.2011 at 12:40
From your AutoCAD Help file:
If the layer state is imported from an LAS file, and it contains linetype or plot style properties that do not exist in the drawing, a message is displayed notifying that the property could not be restored.
That explains the message you are seeing.
Why can't you use the Design Center to drag-and-drop linetypes from one drawing to the other?
Edited by John Connor - 04.Oct.2011 at 14:18
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,156 seconds.
