RSS discussions
Discussion Discussion forum
Topic Closedproblem with layers
 Post Reply Post Reply Page  12>
Author
wishingtree View Drop Down
Newbie
Newbie
Using: AutoCAD2012
Status: Offline
Direct Link To This Post Topic: problem with layers
    Posted: 08.Oct.2011 at 06:55
thax for sharing ,i once have the same problem and now it has been fixed out ,thank you
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 07.Oct.2011 at 11:38
How did you solve your problem?
<<AutoCAD 2015>>
Back to Top
ahmedsobhe View Drop Down
Newbie
Newbie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Posted: 07.Oct.2011 at 08:20
thanks guys for help , I got it.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 04.Oct.2011 at 12:40
From your AutoCAD Help file:
If the layer state is imported from an LAS file, and it contains linetype or plot style properties that do not exist in the drawing, a message is displayed notifying that the property could not be restored.
That explains the message you are seeing.
Why can't you use the Design Center to drag-and-drop linetypes from one drawing to the other?
Edited by John Connor - 04.Oct.2011 at 14:18
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: AutoCAD 2011
Status: Offline
Direct Link To This Post Posted: 03.Oct.2011 at 20:13
What i am asking about is ( transferring layers properties ) to a *.lsa file , with that file I can reuse this layer properties on another CAD file
I noticed that AutoCAD always tells me that line type could not be transferred to the new file however the layers (name,color,line wight .. etc ) are always successfully transferred to the new file, ( line type ) failed in this process.. could any one help me please ?
Back to Top
v_85259 View Drop Down
Newbie
Newbie
Using: revit 2011
Status: Offline
Direct Link To This Post Posted: 03.Oct.2011 at 07:13
dear friend
new.LIN file load any computer automatically come in line type that computer
venkateshan
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 30.Sep.2011 at 12:08
There is no "transfer".  All the routine does is write a line definition to a new .LIN file which can then be used on another computer.
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Using: revit 2011
Status: Offline
Direct Link To This Post Posted: 30.Sep.2011 at 07:41
pls tell me
u r  transfer layer or line type
thanks
s.venkateshan
venkateshan
Back to Top
Newbie
Newbie
Using: revit 2011
Status: Offline
Direct Link To This Post Posted: 30.Sep.2011 at 07:40
Dear friend
what u r problem.u transfer layer or line type.
pls tell me
Thanks
Venkateshan.s
venkateshan
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 29.Sep.2011 at 15:46
My idea addresses only the linetype issue.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,088 seconds.
