RSS discussions
Discussion Discussion forum
Topic ClosedMText Help!!!
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: MText Help!!!
    Posted: 19.Oct.2011 at 13:29
It may have changed to narrow width because the person who did the drawing used the "Fit" option?
<<AutoCAD 2015>>
Back to Top
nh0mad View Drop Down
Newbie
Newbie
Using: AutoCAD LT 2010
Status: Offline
Direct Link To This Post Posted: 19.Oct.2011 at 13:25
I run AutoCAD LT 2010.  So far I have determined it is because all the mtext was set for dynamic columns (I didn't create the drawing). Bottom line is I need to replace all the mtext with no columns.  Biggest question now is why did it all change to such a narrow width? It was fine then I inserted a block (scaled 1:1) into model space and then the troubles started.  If it's as simple as the no columns...great! Just would like to avoid this in the future.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 19.Oct.2011 at 12:03
You inserted the key plan.  Does this mean it was done as a separate drawing?
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 19.Oct.2011 at 07:52
Please let us know what software ( Autocad , Revit ... ) and what release  ( 2000 , 2008 , 2010 ... ) you are using.
Please modify your personnal datas so it will appear at the screen.
nh0mad
Newbie
USING : XXXXXXXXXX ( Autocad 2010 ......... )
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 18.Oct.2011 at 16:47
I have a drawing with 3 different scale vports (3/32", 1/4", 1:1). The width of my text was fine until I inserted a 1:1 keyplan into model space. (I need to freeze/thaw different areas so it had to be in model for the different tabs/sheets).
Here's the problem. I lost the width on all my mtext! Instead of the 14' +/- width it had in model space it is all now 4"!!! Even worse, upon fixing it, as soon as I close and reopen the drawing it is back to the 4" width!  The text is annotative in the dwg.
Anyone seen this before...and have a clue how to corect?
Thanks in advance!!!
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,078 seconds.
