RSS discussions
Discussion Discussion forum
Topic ClosedPROBLEM WITH TRIM
 Post Reply Post Reply
Author
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Topic: PROBLEM WITH TRIM
    Posted: 06.Feb.2012 at 19:17
Just another lucky guess.
<<AutoCAD 2015>>
Back to Top
thegodian View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 06.Feb.2012 at 18:23
THAT SEEMS TO HAVE WORKED.
THANK YOU
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 02.Feb.2012 at 18:07
Maybe it's your EDGEMODE setting?
<<AutoCAD 2015>>
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 02.Feb.2012 at 17:00
Hi All,
  Having a small problem with the trim command. When I pick trim then right click i used to be able to remove whole lines. It now only removes a tiny bit of the line. This happens on all lines not just poly lines. If I pick the trim command and pick a trimming line it works fine.
 Any ideas on how to fix this.
Ian
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,113 seconds.
