RSS discussions
Discussion Discussion forum
Topic ClosedHelp using blocks
 Post Reply Post Reply
Author
goŘn View Drop Down
Newbie
Newbie
Using: AutoCAD
Status: Offline
Direct Link To This Post Topic: Help using blocks
    Posted: 15.Feb.2012 at 16:13
Hi guys,
I use CAD everyday, and generally the blocks I use are the same, I know there is a way to save things as a block (a triangle for example) then I can just insert that block by using the reference
Can anyone explain how to do this this
Thanks
goŘn
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 15.Feb.2012 at 16:27
You can follow the dialog of the BLOCK command.
Or you can even make a block without starting any command:
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
goŘn View Drop Down
Newbie
Newbie
Using: AutoCAD
Status: Offline
Direct Link To This Post Posted: 15.Feb.2012 at 16:39
Thanks Vladimir
This is what i was looking for, thank you for shining a light on my problem
Star
Back to Top
goŘn View Drop Down
Newbie
Newbie
Using: AutoCAD
Status: Offline
Direct Link To This Post Posted: 15.Feb.2012 at 16:51
Is there a way to name a block and save it so then you can just call it using the command line ?
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 15.Feb.2012 at 18:27
You use the Insert command for a block or....
Drag/Drop it from Design Center or....
Drag/Drop it from a Tool Palette.
You cannot type the name of the block at the command line and have AutoCAD bring the block into your drawing.  If you tried that as soon as you hit the Enter key AutoCAD would return the words:
Unknown command "BLOCKNAME".  Press F1 for help.
<<AutoCAD 2015>>
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 15.Feb.2012 at 23:20
Hint:  Of these options, the Tool Palette idea is the best/most efficient!
Dve.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
goŘn View Drop Down
Newbie
Newbie
Using: AutoCAD
Status: Offline
Direct Link To This Post Posted: 16.Feb.2012 at 09:51
Thanks guys some really positve feedback there, and also helpful solutions just what i wanted.
 i'll try find a tutorial on the design centre & tool palette,
feel free to post a link, but thanks for your answers
Cool
EDIT**
Is there a way to save & send tool palettes so my co worker can use the same palette ?
Thank you
Edited by goŘn - 16.Feb.2012 at 10:29
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 16.Feb.2012 at 11:50
Info regarding the Design Center can be found in your User's Guide.
Info regarding Tool Palettes can be found in your User's Guide and in the Customization Guide.
Tool Palettes can be exported and imported, thus allowing you to share your tool palettes with your coworker.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 16.Feb.2012 at 20:12
The key to sharing tool palettes is making sure that all block library or referenced block file calls from the palettes go to a server folder that all users will see.  Sharing is caring, so it's probably best if that folder has also been set up as read-only.
Wink
Dave.
Dave Hein, P.E.
Back to Top
goŘn View Drop Down
Newbie
Newbie
Using: AutoCAD
Status: Offline
Direct Link To This Post Posted: 17.Feb.2012 at 17:52
Good points, thanks for pointing that out, having it read-only with just one or two people creating the blocks will rule out room for error Wink
Looking towards getting my tool palette up to scratch with perfect blocks, hopefully this will reflect in my designs
Thanks
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,145 seconds.
