Over 1.127.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
Post Reply
| Author | |
LGeneBartlett
Newbie
Joined: 15.Apr.2011 Location: United States Using: AutoCad 2010 Status: Offline Points: 13 |
Topic: Xref-visibility of attachmentPosted: 17.Apr.2012 at 15:05 |
When I attach an xref, I can barely see it in the dwg file! Is there a setting, etc. that will give it the visibility quality of a normal drawing or block - I don't have time to redefine floor plan blocks everytime I edit - need to be able to see the attached xref. Anyone help me w/ this issue?
email me at: gene@bartlettdesigndrafting.com Edited by LGeneBartlett - 17.Apr.2012 at 15:07 |
L Gene Bartlett
John Connor
Senior Member
Joined: 01.Feb.2011 Location: United States Using: AutoCAD 2018 Status: Offline Points: 7175 |
Posted: 17.Apr.2012 at 18:08 |
Have you checked VISRETAIN?
If that is not what you are after then go to Options > Display > Fade Control Xref Display (it is in the lower right hand corner of the tab). It controls the intensity of an Xref fade. The slider changes the number in the box next to it. Edited by John Connor - 17.Apr.2012 at 18:11 |
<<AutoCAD 2015>> |
LGeneBartlett
Newbie
Posted: 17.Apr.2012 at 18:11 |
Yes, visretain is set to retain any & all revisions. Actually the setting for my question is XDWGFADECTL - its default on 90 & should be reset to 25 to 50
Cary, in West Virginia actioned the correct answer - he's quite up to speed on AutoCad 2012 settings! Thanks big time for your reply & time.
L Gene Bartlett
Post Reply
Tweet
This page was generated in 0,086 seconds.
Topic Options
