Over 1.132.000 registered users (EN+CZ).
Discussion forum
Post Reply
| Author | |
angee7890
Newbie
Topic: Problem with materialsPosted: 21.Jul.2008 at 12:52 |
Hello. I have problem with using meterials on objects. I work on Autocad 2008, and when i try to set a material on one object, its automaticly add to ALL objects in my scene. I have been reading help- i have not found a thing.
Please help. ![]() |
Vladimir Michl
Moderator Group
Joined: 26.Jul.2007 Location: Czech Republic Using: Autodesk software Status: Offline Points: 2188 |
Posted: 21.Jul.2008 at 13:37 |
Materials are attached to the selected objects. Are you sure you have individual objects, not a block or a group? See also:
Vladimir Michl (moderator)
angee7890
Newbie
Posted: 21.Jul.2008 at 13:52 |
Im sure. I have nothing selected, but when i choose a material from the list, it is atached to all object and remove material tool doesnt work
Vladimir Michl
Moderator Group
Posted: 21.Jul.2008 at 14:15 |
If you start the MATERIALASSIGN command (or ._MATERIALASSIGN to make sure it is not redefined) and nothing is selected, it should ask for an object selection.
angee7890
Newbie
Posted: 21.Jul.2008 at 14:19 |
HeHe, problem is solved. To atach a material to an object you must create new material, and then select objects. Ive discovered it while ago.
Post Reply
Tweet
This page was generated in 0,113 seconds.
Topic Options
